Рентгеновское питающее устройство Indico IQ RF 50 kW
IskanДата: Вторник, 09.Июн.2026, 11:58 | Сообщение # 1
Мядель
Здравствуйте! В баке-танке РПУ Indico IQ RF 50 kW пробиты все высоковольтные диоды с маркировкой JB574 HVCA. В интернете о таких диодах никакой информации не нашёл, может кто сталкивался с такой проблемой? Меня интересуют характеристики этих диодов.
Сообщение отредактировал Iskan - Вторник, 09.Июн.2026, 15:11
AlexiumДата: Вторник, 09.Июн.2026, 15:57 | Сообщение # 2
Вот ответ Гугла
The component marked JB574 is a High Voltage Rectifier Diode manufactured by HVCA (HV Components Associates / CKE). These are specialized silicon avalanche diodes widely used in high-voltage power supplies, medical equipment, and microwave ovens.Key SpecificationsWhile manufacturer datasheets are proprietary, JB-series HVCA diodes generally feature:\(\text{V}_{RRM}\) (Peak Repetitive Reverse Voltage): Typically between 8 kV and 12 kV.\(\text{I}_{F(AV)}\) (Average Forward Current): Generally around 100 mA to 500 mA.\(\text{t}_{rr}\) (Reverse Recovery Time): Standard recovery speeds designed for high-frequency or \(50 \text{ Hz} \slash 60 \text{ Hz}\) line rectificati
IskanДата: Вторник, 09.Июн.2026, 16:18 | Сообщение # 3
Мядель
Хотелось бы информацию поточнее.
medtehДата: Среда, 10.Июн.2026, 11:20 | Сообщение # 4
Admin
The component marked JB574 is a High Voltage Rectifier Diode manufactured by HVCA (HV Components Associates / CKE). These are specialized silicon avalanche diodes widely used in high-voltage power supplies, medical equipment, and microwave ovens.Key SpecificationsWhile manufacturer datasheets are proprietary, JB-series HVCA diodes generally feature:\(\text{V}_{RRM}\) (Peak Repetitive Reverse Voltage): Typically between 8 kV and 12 kV.\(\text{I}_{F(AV)}\) (Average Forward Current): Generally around 100 mA to 500 mA.\(\text{t}_{rr}\) (Reverse Recovery Time): Standard recovery speeds designed for high-frequency or \(50 \text{ Hz} \slash 60 \text{ Hz}\) line rectificati.
Компонент с маркировкой JB574 — это высоковольтный выпрямительный диод производства компании HVCA (HV Components Associates / CKE). Это специализированные кремниевые лавинные диоды, которые широко используются в высоковольтных источниках питания, медицинском оборудовании и микроволновых печах.Основные характеристики Несмотря на то, что спецификации производителя являются собственностью компании, диоды HVCA серии JB обычно имеют следующие характеристики: \(\text{V}_{RRM}\) (Пиковое повторяющееся обратное напряжение): обычно от 8 до 12 кВ.\(\text{I}_{F(AV)}\) (Средний прямой ток): Обычно от 100 мА до 500 мА.\(\text{t}_{rr}\) (Время обратного восстановления): Стандартные скорости восстановления, рассчитанные на высокочастотную линию или \(50 \text{Гц} \косая черта 60 \text{Гц}\) исправляющий
IskanДата: Среда, 10.Июн.2026, 12:23 | Сообщение # 5
Мядель
Перевести я и сам могу с любого языка с современными возможностями. Меня интересуют не приблизительные, а точные характеристики диодов.
1. Дефибриллятор ДКИ-Н-1...[Alex_UssR (29.Июн.2026)]
2. Аспиратор-ирригатор H...[vladi (29.Июн.2026)]
3. xGenius DS[bektyish (24.Июн.2026)]
4. Стол неонотальный с п...[kostya1990 (23.Июн.2026)]
5. Анализатор биохимичес...[Alexium (22.Июн.2026)]
6. МАВИТ Улп-01[svrom (21.Июн.2026)]
7. Стерилизатор паровой ...[spynet (11.Июн.2026)]
8. Рентгеновское питающе...[Iskan (10.Июн.2026)]
9. Ищу схему аудиометра ...[Bittbox (08.Июн.2026)]
1. Timko523[29.Июн.2026]
2. Vandenhul[29.Июн.2026]
3. DenisKYU[29.Июн.2026]
4. metrolog_vec[29.Июн.2026]
5. Anellee[28.Июн.2026]
6. pharaoh7979[27.Июн.2026]
7. XLeo0[26.Июн.2026]
8. Assa76[26.Июн.2026]
9. NikolaySut[26.Июн.2026]
10. ggkenj[26.Июн.2026]
