Модератор форума: evven
Особые расходники
navesДата: Пятница, 06.Июн.2014, 12:47 | Сообщение # 1
У вас сообщений: 1070
Случайно наткнулся
http://www.maxoptix.com/maxoptix-medical-grade-dvd-rw-10-pack/
пачка DVD-RW за 70 баксов
Цитата
Product Description
Maxoptix brand medical grade DVD+RW media. 100+ year archival life, DICOM compliant and in stock. These medical DVD+R/W (rewritable) are compatible with most modern data drive recorders. We developed this product specifically to meet the needs of the medical community as a direct replacement for Sony P/N DPW-120MD disc which has been discontinued. They function flawlessly in the Sony DVO 1000 Medical recorder that is used extensively to record patient studies and data.
DICOM compliant
100 year archival life
Hard coated on top of lacquer layer for UV protection against heat, light, moisture and oxidation
Exceeds orange book for block error rates (BLER)
Slim Line Jewel case and insert Included in all disc prices. Optional shrink wrapping with order.
старый баян про Ethernet кабель за 500 баксов, наверное, многие видели
http://sysadminblog.ru/humor....ov.html
http://usa.denon.com/us....onNA%29
Цитата
Denon's 1.5 meter (59 in.) proprietary ultra premium Denon Link cable was designed for the audio enthusiast. Made from high purity copper wire and high performance connection parts, the AK-DL1 will bring out all the nuances in digital audio reproduction from any of our Denon DVD players with the Denon Link feature connected to a Denon Link enabled Denon A/V receiver. The AK-DL1 employs high level tin-bearing alloy shielding not typically available in commercial cabling, to eliminate data loss caused by noise. Additionally, signal directional markings are provided for optimum signal transfer. Attention to detail when building this cable was used by employing high quality insulation and woven jacketing to reduce vibration and to add durability. Rounded plug levers help prevent breakage.
PS Искал похожую тему на форуме, не нашел
1. pavel1264[21.Июн.2026]
2. novatox[20.Июн.2026]
3. nsn112[20.Июн.2026]
4. Inna2234[19.Июн.2026]
5. karanaevazat[19.Июн.2026]
6. Nurgaliev[18.Июн.2026]
7. vsl_pupkin[18.Июн.2026]
8. phanton2031[18.Июн.2026]
9. ilyasayno[18.Июн.2026]
